I know how to use MS Publisher but my printer won't work. Thing is, I need to print gate-folded brochures, utmost 1,000 pieces. My deadline is at the end of this month. So any suggestions what should I do instead? I think I can just go for some printing companies out there.
It doesn't appear to save you any time or money. The initial prices will be high, and then the costs of paper, ink, and other supplies will add up. Print shops, on the other hand, are designed to generate large volumes of material at a low cost. They'll also most likely be of superior quality, as they'll be printed using high-end industrial printers (https://printerhow.com/best-8x10-photo-printer/) that are well beyond your budget.
Get your professionally designed brochures, flyers, magazines and other printing design needs quickly and easily.
Whether you are a printing company, looking for a very flexible design solution, a professional advertising agency or a home designer with more work than you can handle. Then we are your first choice.
https://www.graphic-designs.com.au/print-design
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
For all printer or digital printer brochures www.allbrochures.net
Canon imagePROGRAF iPF5100 All Brochures
Yes, I think it's best to print brochures from some online printing companies out there, especially now that you're running out of time. You don't have to go all through the trouble. Just specify what you want to do with your brochures and they will take care of everything. You can go and check this site: http://www.printrunner.com/brochure-printing.html Other than the gate fold option, they also offer other types of folding like half-fold, tri-fold, Z-fold, double-gate fold, double-parallel fold- and roll-fold.
SOURCE: not printing properly
Print heads need to be cleaned cause they are clogged which is why even replacing the cartridges is not fixing the problem.
If the printhead can't be cleaned then a new printer is in order.
Testimonial: "thanks I'll try that"
SOURCE: blinking/flashing lights(orange & green) &
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
SOURCE: My HP deskjet 2050 all-in-one
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
SOURCE: My HP Officejet 6500 Wireless
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
SOURCE: My canon MX340 won't print,
Error 5200: Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I think in cases of a bulk order it's best not to do it on your own and get in to contact with some online printing services. I've had to go through something similar very recently, it was a wise choice to go to an actual printing company
