Have used head cleaner casset and still doesnt work
SOURCE: JVC GR-D250 does not record properly
When playing the tape in the camera itself, do you hear sound? If so, its something with the connection cable... is not, you will need a professional repair, you can do nothing except the head clean which you did? Sorry.
SOURCE: JVC GR-DX307 Mini DV Digital Camcorder
I need Drivers for JVC GR-Dx307.
I do not have the CD for my camera,Kindly help me to get the Tape data to my computer,
Regards ,
Basha
Bellary
[email protected]
SOURCE: head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
SOURCE: CAMCORDER JVC GR-D60EK
This works on mine simply cover and uncover the lens with your hand ! or tap the frount of the lens carefully .. the message disappears !
SOURCE: i get 5 constant black lines on playback of my JVC
I had the same problem, just spray electronic switch cleaner onto the tape reader heads. Solved my problem first time.
fast foreward or reverse shows a very pixelated semi picture.in play it plays pixely for half second and says head cleaning required. after cleaning head 1, 2 , 3 times still says head cleaning required hel
can record and play over old tapes but will not play on the same old tapes
