When mine did the same thing, I just sprayed each mechanism with some spray lubricant to free it up, worked great. Same in the latches. WD-40 to the rescue.
You have to replace the SKS cores you don't want with mates to the ones you do want.
I would suggest replacing the snowboard cores with ones that are the same # as your towers since then you are only replacing 2 cores instead of 4 and it is cheaper.
The key should have a number on it that tells you what core it goes too. You can either contact yakima and get the exact cores you need or go into your local dealer and see if they have them in stock or can order for you.
The main web page for Yakima Products, Inc. provides a search feature that will match up the rack model you need for your particular car. They will also be able to supply a manual for any model they sell. Included is the website link!
hello,silly question is the aerial connected, also if you've got s skybox make sure it's connected i'e the aerial is in the skybox and a lead from the skybox to the tv
Hi! Yes its possible if manual you want it to be. Try this, If the cargo doors have separate fuse from the fuse box then just remove the fuse and it would work manually. If you wont find the door fuse then you should work on the door manually. Open the cargo door trimming and you will find a motor inside the door. The motor has a connector that leads to the lock. Remove the connector to cut the power supply to the motor and you'll be on manual now. Hope this helps and have a good one!
good old duct tape... i would get some silicone caulking and run beads along the cracks in the box to seal the water out. not sure what colour that is but the caulking comes in many colours as well as clear.
Robert
please take a moment to rate this solution.. thanks
515-707-3551 $25 each plus shipping for 3 panel sets $15 each plus shipping For Single Skybox by Maytag -Assorted Teams & sports (Three Panels Total) (some are just the front panel) Shipping is $10
These Panels Are New In The Box, Opened For Photo. Interchangeable Front and Side Sports Panels for Skybox personal vendor. Panels fit seamlessly on the front and sides of Skybox; front is backlit by the unit. Panels Can Also Be Used As Wall Decorations Or Anything You See Fit To Use Them For. Change out sports panels for the season with ease, whether college or professional. Constructed of durable polystrylene with vibrant full color sports logo art. One panel measures 20 inches by 16.5 inches(front); Two panels measures 15.5 inches by 30.6 inches.
