Depending on year its 15 amp for 2012. http://www.dodge.com/download/pdf/manuals/2012-Avenger-OM-3rd.pdf
SOURCE: need fuse diagrams for a 1997 dodger avenger
Here is the one from the inside. It is in the correct orientation as well.
SOURCE: cigarette lighter
there is two fuses one under the hood along with a relay and another fuse under the dash on the driver side
SOURCE: 2002 dodge grand caravan--radio cigarette lighter power out
there is another fuse box under the dash on the driver side. if you have your manual, look up the fuse positions in it and find the proper fuse. if i read your ad properly you have no power to the radio or cigarette lighter. this circuit is on one fuse in the fuse box under the drivers side dash
SOURCE: No power to cigarette lighter, cannot charge up devices.
You may be able to contact the dealer and ask over the phone the location of the fuse(s).
-or-
Use a friends manual, because I don't believe they have a pdf of the manual on the dodge website. If you find a site with one post it here, because I have yet to find one and would like to have it.
-or-
With a electrical tester and with the cars ignition on, test all fuses and replace the ones that don't have power on both sides. If all fuses are good then you have eliminated the problem being a fuse.
