My Maytag LAT9235AAE top load washer fills up with water but does not aggitate or spin. The timer moves thru its cycle like it normally would but nothing is happening. I have checked the dorr switch and the motor for continuity which it has. Check all connection for either burnt or loose connections. Everything is fine. I was told it may be the load switch, but if it was the load switch the timer could not go thru all its cycles right? Water level switch is working because it fills to each level I request. Could it be the timer???? Or what am I missing???
I had the same problem. and I did the suggestion dated 9/26/06. Too another piece of hose and attached it to the water level switch and blew into it. and the machine began aggitating. My question is... DO I replace the hose?? or switch?? Now that I have purchased a new machine. I find a solution, Oh well. thanks df
Pt, as long as you verified the lid switch is good, do this simple test. Get a piece of hose the same size as the one going to the pressure switch, connect it and blow into it. See if it starts agitating. If it does, there's your problem..Catriver post back.
The pressue switch hose goes to the back of the water level selector level switch right? If so as soon as I remove that hose more water fill the tub and does not stop....I blew in it as you stated and all that happened were bubbles coming thru the tub. Is there something I did wrong or something I missed!
Okay I did what you said to do...A straw fit it perfectly. I heard the switch engauge and disengauge....This stopped the water from filling but did not make the washer aggitate. The timer is moving thru all of its cycles as if the it was actually running. What else could it be???
So Catriver any other suggestions. I am all ears.
I have a LAT9614aae with the same problem. However I do not know what hose to blow into...
Does someone have an image they can post?
Russell Disberger
Washer will not fill. Timer on and counting down but that is it
start cycle nothing happens, turn timer and it will spin.water valve wont energise
