It will not power on. the green light is on in the charging phase.
SOURCE: bluetooth ear piece
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
SOURCE: sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
SOURCE: Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
SOURCE: i have a HBH-PV705 bluetooth headset that is
I am having the exact same problem with my PV705! I've followed all the directions and tried charging it numerous times but still nothing.
