NorStar M7324 Telephone Logo
Posted on Apr 23, 2017
System adds default lady message on to my main outgoing message
I feel confident that I have perused the manuals and tried numerous things, but when I listen to my main outgoing message, the system has added on the default lady who says, "Using the dial pad, enter the extension you wish to call. To access the directory, press the # key. To leave a message, press the * key."
All I am trying to do is offer my personal message, and nothing else.
Your assistance is MUCH appreciated. Working on this has NOT been my favorite way to spend a weekend!
Cheers,
Cynthia
Lolohayma
Level 1:
Habit-Forming:
New Friend:
  • Contributor 17 Answers
  • Posted on Apr 24, 2017
Lolohayma
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
17
Questions
Helped
5952
Points
47
In order to help you have to include the make and model number of unit
2 Related Answers
Anonymous
  • 192 Answers
  • Posted on Apr 27, 2009
SOURCE: Directory Access Changes
Changing CCR tree...
Ok, for the first part:
Changing the Greeting in the Auto Attendant via CCR tree... you have to get into the ADMIN mailbox:
-> FEATURE 9 8 3
-> Password 1020000 for 3 digit extensions -or- 120000 for 2 digit extensions
(these are the default password, but can be changed)
-> OTHR
-> CCR
-> ADMIN
-> TREE 1 and press OK
-> CHNG
-> Path 0
-> REC then press PLAY to listen to the greeting, and ensure that is the one that you need to change
-> REC the new message
-> remember to SAVE! otherwise all is for not.
THIS MAY BE REQUIRED FOR OTHER TREES ex 2 or 3, listen too all trees and change if required... same steps to get into the trees and prompts.
Ok, second part:
To change the locations of where Press 1 goes do that same steps as above, but Path 1 is for number 1...
Path 2 is for the number 2... so on and so forth.
consultel1
george peters
  • 860 Answers
  • Posted on Sep 26, 2009
SOURCE: Accessing company phone directory
Sounds like you shut the CCR tree down. Go to AA>table>1>CCR>chng>1>enable. that should take care of it
When I REPLY to SOME emails I get"message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was ....... etc." But when I create a new...
If you are using email like OutlookExpress, or Windows Mail, you may have linked to multiple email address' . So when you hit Send / Recive, its checking 2 or more email adds.. If so, one of them is not setup correctly for the Outgoing server. When you create a new email, it uses your default main email address, which is apparently setup correctly. When you reply to a mail which came in on the "other" account the outgoing server setup is wrong, resulting in the message you recieve.
You should go over the server setting for each account other than your default email account.
How can i add multiple main accounts in my outlook i tried but i cant access rediffmail.com
I am assuming you know how to add a second account. Things you need to check, sometimes the username wants the domain name as well. For example, if your email address is [email protected], your username will be [email protected].
Another thing to look for is the ports rediffmail.com uses for incoming and outgoing email. Outlook will use the defaults, a lot of mail providers will not accept the defaults thus not allowing you to connect. Double check with rediffmail.com the ports you need to configure.
1helpful
Add a signature in body of email
It is possible to add a signature in body of email. Follow the below mentioned steps.
1. Log into your Yahoo Account.
2. Click on Options and then select Mail Options.
3. Now on the left handside click on Signature.
4. Select the option where it says Show a signature on all outgoing messages.
5. Now you can create a signature and then click on save. All your outgoing messages will now have a signature by default.
Oct 11, 2010 • Yahoo Mail
7helpful
2answers
I need to change the outgoing message on the main line. I can change the personal greeting, but I cannot find instructions regarding changing the main line's outgoing message
For Partner Voice Messaging....
Dial into voicemail. WHen prompted for the mailbox number
Enter 0 #
Pswd the default is 1234 followed by #
Option 3 is the record Automated Attendant menu prompt
the rest is self explanatory.
2answers
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 • Cell Phones
8helpful
How do you change the message on my GE 28821FE2-A cordless phone?
1. Make sure the answering system is ON. 2 . Press and hold the announce button until the speaker announces “RECORD ANNOUNCEMENT AFTER TONE“. 3 . Begin speaking after you hear the beep. 4 . Release the button when you finish your announcement. NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing. Sample Outgoing Announcement Hi, this is (use your name here), I can’t answer the phone right now, so please leave your name, number and a brief message after the tone, and I’ll get back to you. Thanks. NOTE: The maximum recording time for the outgoing announcement is 2 minutes. Reviewing and Choosing the Announcement Press and release the announce button to review and select this one as your outgoing announcement. NOTE: Press the PLAY/STOP button at any time to stop playing the announcemet
1helpful
Model# 27909EE1-A the automatic answering system is not working
Here you are...
Recording the Outgoing Announcement
For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible.
2. Press and hold the announce button on the base until the speaker announces "RECORD ANNOUNCEMENT AFTER TONE".
3. Begin speaking after you hear the beep.
4. Release the announce button when you finish your announcement.
NOTE: The maximum duration allowed for outgoing message is 2 minutes.
Also, here's a link for your manual..
http://www.smithgear.com/ge-27909ee1.html
If this helps, plz rate this 'fixya'. Thank you kindly.
4helpful
I Lost my manuel and can't figure how to change or add a voice outgoing message
HERE is the manual! See page 11 of the PDF document which is page 18 and 19 of the manual!
Good Luck!
Brian
4helpful
Help! I feel dumb. How to set predictive text?
To Change Default Text Entry:
Menu
Messaging
Settings <left soft key>
All Msg <1>
Entry Mode <5>
Chose WORD to default to Predictive Text.
Hope This Helps.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
