Cooktops Logo
A
Anonymous Posted on Mar 11, 2012
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
Why does the control knob for the left hand front burner operate differently to the other three? Why does the whole area of that burner ie the outer circle, not heat up? Is there a particular way of wiring the appliance to the power source in order to resolve this?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 27, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
206
Points
0
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 19, 2007
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Anonymous
  • 619 Answers
  • Posted on Jan 05, 2008
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
douglas smith
  • 1462 Answers
  • Posted on Nov 20, 2008
SOURCE: Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Anonymous
  • 111 Answers
  • Posted on Dec 19, 2008
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Anonymous
  • 1136 Answers
  • Posted on May 24, 2009
SOURCE: I cannot REPLACEMENT KNOBS fOR model # 5D02
Hi, The part #74009592 for your knobs. This # is for a black knob. Let me know if I can assist you further.
Vic
Electric schott ceran glass cooktop model number ISE630WS01 right burner not working
Based on your question that the right front burner of your Schott Ceran glass cooktop is not working, here are some steps you can try to troubleshoot the issue:
  1. Check the power supply: Make sure that the cooktop is properly connected to a power source and that the circuit breaker or fuse is not tripped. If the circuit breaker is tripped, reset it and try turning on the burner again.
  2. Check the burner control switch: The burner control switch regulates the power to the burner. Check if the switch is loose, damaged, or defective. You can test the switch for continuity with a multimeter to determine if it is functioning properly.
  3. Check the heating element: If the burner control switch is not the problem, the issue may be with the heating element. Check the element for visible damage, such as cracks, burn marks, or discoloration. If you see any damage, the element may need to be replaced.
  4. Check the wiring: Check the wiring connections between the burner control switch and the heating element. If any of the connections are loose or damaged, this may be causing the issue.
  5. Test with a different burner: If you have multiple burners on your cooktop, try testing the right front burner with a different control switch or heating element to determine if the issue is with the burner or another component.
The above are basic means of troubleshooting, the following below will add more to the solution above;
Check the control board: The control board is responsible for sending power to the heating elements. Check the control board for any signs of damage or burning, and test it for continuity using a multimeter.
  • Check the thermal fuse: The thermal fuse is a safety device that cuts off power to the heating elements if they overheat. Check the thermal fuse with a multimeter to see if it has blown. If it has, you will need to replace it.
  • Check the switch relay: The switch relay is another component that can cause the burner to not work. Check the switch relay for any signs of damage, and test it with a multimeter to see if it is functioning properly.
  • Test the voltage supply: Use a multimeter to test the voltage supply to the burner. If there is no voltage, this could indicate a problem with the control board, thermal fuse, or switch relay.
  • Check for loose connections: Inspect all wiring connections between the control board, switch relay, and heating element. Loose or damaged connections can cause the burner to not work.
  • Feb 05, 2023 • Cooktops
    Schott Ceran Hob. Please could you let me know what knobs I can buy for it? Thank you.
    Question edited for clarity.
    Question moved to Schott Ceran category.
    Replacement knobs, but it should go by the numerical model number in the search query as well.
    https://www.google.com/search?q=schott+ceran+cooktop+replacement+knobs
    How do i remove ceramic cooktop on my ilve oven Mod. PE90WMP/1?
    Ignore pupahecud - one of many FIXYA fraudulent spammers.
    Contact Eurolinx ILVE for assistance - see the link below for phone numbers in your country.
    https://manuals.appliancesonline.com.au/pe90wmpss/pe90wmpss.pdf
    Feb 17, 2019 • Cooktops
    Frigidaire ceramic stovetop burner not working
    The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
    If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
    Aug 30, 2014 • Cooktops
    Whirlpool How To
    so sorry for the way late reply!
    if the knob does not fit you'll need a new one...
    i found them here....
    https://www.repairclinic.com/Shop-For-Parts/c31-x72636333303234/Rcc3024-Knob-Dial-Button-Parts
    not sure which is yours as the model # should have a few more # or letters. Take a look at them and see if one matches.
    best to you.
    Maytag schott ceran front eye wont get hot
    I navigated the SCHOTT website to find a solution and was able to find out how to properly clean my SCHOTT stove top. I would check the Ceran FAQ list to see if your question is answered before anything else.
    2helpful
    Whirlpool schott ceran induction plate doesn't get hot
    magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
    • Cast iron pans
    • Any black metal pans
    • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
    Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
    2answers
    Should I buy a two burner unit if available? Or a new cooktop?
    Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
    Dec 29, 2009 • Cooktops
    Top Cooktops Experts
    Paul Carew
    ADMIN Andrew
    ADMIN Andrew
    Are you a Cooktop Expert? Answer questions, earn points and help others
