Hello, my top dishdrawer just started beeping and flashing the screen every 2 seconds while it wasn't being used. It is set to rinse but the screen cycles between showing the rinse screen, and illuminating the whole panel. Inside the rinse light is on and then it goes off in time with the 2 second cycle. I tried resetting at the wall - no good, it just starts up again. Opening the dwawer doesn't stop it either, and the power button just cuts off the cycle as it starts but it still cycles. It is driving me batty! Any suggestions greatly appreciated.
Leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
SOURCE: current service manual for the Fisher & Paykel DD603SS dishdrawer
I realize this is an older post but for information's sake in case someone happens across this subject, you can get the manual for a DD603 series dishdrawer here:
http://www.fisherpaykelparts.net/index.php?categoryid=115&productid=18
There is no service manual in the enclosure however if someone has a copy I would greatly appreciate an emailed copy.
An update on the fault - The top drawer is doing the start up 4 rising beeps while showing the last used cycle on the LCD, and then shutting off. A second later it repeats the same thing again, and again, and again.... It won't take any button inputs and only turning the power off at the wall stops it. This all began while the dishwasher hadn't been used for many hours. The bottom drawer works fine.
Help please!
