SOURCE: I have a87900 model skyscan,can;t get it reset after replacing batteries
http://www.skyscaninfo.com/content/
they have instructions online
SOURCE: Skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone
and select your zone then press set button.
to normal mode and adjust the current time.
SOURCE: need help setting the time on the clock it is a
link below will tell you how to set clock. scroll down about half way.
http://www.skyscan.info/content/manuals/15-model-28500.html
SOURCE: SkyScan Atomic Analogue Clock # 28512
read the manual here
There are four buttons on the back, at the bottom. From left to right they are Pacific, Mountain, Central and Eastern
SOURCE: skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
The SkyScan ATOMIC Clock
With the Skyscan Atomic Clock, you have the most accurate timepiece within the continent. It can receive the time signal transmitted by the National Institute of Standards and Technology (NIST), which is regulated by 3 atomic clocks and deviates less than 1 second within 3,000 years. The NIST broadcasts the time signal (WWVB, 60kHz) continuously from Fort Collins, Colorado. This signal can be received anywhere in the continental USA that long wave (AM) radio reception is possible with a portable radio. It is expected that the signal can cover a distance of over 2,000 miles from the transmitter. Therefore, your clock will receive the signal within the broadcast range anywhere an AM signal can be received; generally the signal cannot be picked up in massive metal and concrete structures unless near a window. In addition, some environmental effects (see next page) may affect the transmitting distance.
