This machine has never been used for sewing or embrodering! ugh i am getting frostrated!
SOURCE: Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I am getting the message connection error check USB cable and make sure the power is turned on.
Both are OK I began this problem when I got a new Gateway with Vista Please download a driver or a solution.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
SOURCE: Singer CE0100 Futura connection error....
Hi I had the same problem sent question to Singer and this was their reply
"Do you have Vista 32-bit or Vista 64-bits? Unfortunately the CE-100/200 machine will not be compatible with either Vista 64-bit systems or the newest Windows 7 computers. The CE-100/200 will only be compatible with Windows 98 through Vista 32-bit operating systems.
This appears to be a hardware issue and not something that we will be able to create a patch to correct. Drivers necessary for 64-bit operating systems are not compatible with the CE-100/200 machines." so I guess we are SOL
