This is the seatbelt indicator, its not seeing that your seatbelt is fastened ifthe light stays on and the chime keeps going off.
There is a switch inthe seatbelt that closes when the seatbelt is buckled, and if not, thelight stays on and the chime goes off.
There are a couple reasons thiscould happen. It could be a wiring issue going to the seatbelt buckle,or more likely the buckle itself. Your truck is pretty new, so if youare under 36,000 miles the repair would normally be covered underwarranty.
Also, I suggest check the Repair Manual for
Jeep-WK-Grand-Cherokee-Section-08O-Restraints (page 473 and next, for Seat Belt)
Hope helps with this (remember rated this) Good luck.
have seat covers i want to install i need to remove the seat belts to do so..
