I would say you have a bad jazz board,do this open the right hand side door of the fridge,you'll see on the touch pad the up and down arrows,hold the light switch in and press the down key three times,let go of the light switch press the down button again and i think it says like s and p can't remember but press the down one more time and you should see 4 and 4 or whatever settings you had if you see this close the door,open the freezer, by doing what i told you you manually put it into defrost,if you hear the compressor running the board is bad part WPW10503278 and i have to tell you i've changed quite a few of these boards.also if the strip between the doors are hot check you coil on the bottom,usually when this happens the condenser coil is blocked with dust or the condenser fan isn't blowing,if you ever find the fan not blowing you can get a house fan and blow it onto the compressor and coil this will keep it cool until you change out the fan motor and you won't loose any food but that's another day.your coil might just need to be cleaned or the jazz board could be causing this because the compressor is running longer than it should.if you unplug the fridge,melt out all the ice off of the coil as best you can but the more the better you'll be able to use the fridge like normal for like 10 to 12 days then the coil will freeze up again so order the board melt out the ice with a hair dryer and you should be fine,if you need a hand programming the new board let me know i would tell you how to do it but i don't know if people are getting my answers nobody writes back,so open the freezer door,open the right side door,hold the light switch in,push the down button three times,let go of the light switch and push the down pad again and one more time you should see settings again,close the door,if compressor is running the board is bad.
https://www.youtube.com/watch?v=HUoGLZYv...
one more thing if you remove the bottom kick plate there should be a tech sheet either folded up and it's in the kick plate or it's in a plastic pouch taped up to the floor check right side but could be on left too and clean the coil while you're down there
https://www.youtube.com/watch?v=aqptKoBx...
for some reason the other video isn't working that i sent up above.go here and see how to remove board.
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: Amana refrigerator A4TXNWFWWO1 >top freezer,
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
