HP Wireless Assistant says it is turned off and Assistant can not turn it on from there, but gives no clue what to do. The light on my f12 key is on as normal. When I hold the fn key and press f12 nothing changes. There is no switch to turn on wireless like the older laptops. In one search they said there would be a certain key to push. I wondering if maybe the WLAN Module might have gone BAD?
Here are some essential step that you have to follow.
Connecting to a WLAN
To connect to the WLAN, follow these steps:
1. Be sure that the WLAN device is on (the wireless light is white). If the wireless light is amber, press
the wireless action key (f12).
2. Click the network icon in the notification area, at the far right of the taskbar.
3. Select your WLAN from the list.
4. Click Connect.
If the network is a security-enabled WLAN, you are prompted to enter a network security key, which
is a security code. Enter the code, and then click OK to complete the connection.
NOTE: If no WLANs are listed, you are out of range of a wireless router or access point.
NOTE: If you do not see the network you want to connect to, click Open Network and Sharing
Center, and then click Set up a new connection or network. A list of options is displayed. You
can choose to manually search for and connect to a network or to create a new network connection.
After the connection is made, place the mouse pointer over the network icon in the notification area, at
the far right of the taskbar, to verify the name and status of the connection.
For futher detail about WLAN and other features, please read its manual, you will definitely get some useful stuff.
To make it easy to you, user manual can be downloaded from the below linkhttp://h10032.www1.hp.com/ctg/Manual/c02...
best of luck!
SOURCE: my asus laptop wireless switch does not work
well you erased the drivers for the fn keys and the wireless go to the manufacturer website and type the model of if possible laptop or motherboard and download the drivers for wireless and media controls
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
SOURCE: fn key combo for acer aspire 3680 wlan when wireless switch broke
on pressing fn+F1 will give you the details of all the combo keys that you can select find out your one
SOURCE: can't enable Dell Wireless 1390 WLAN Mini-Card
I was using the wireless network, disabled the radio and after reboot was unable to get it to save the enable click. After reviewing all software options listed here - checked wireless adapter setting in BIOS - it was turned off! Turned this on in BIOS and upon boot was able to access wireless network again. Hope this helps you.
SOURCE: where is the wireless switch
when you press these two keys , alight to indicate wirless is on or off ..
do you see a light come on anywhere on the notebook aropud keyboard or on the sides of the laptop ?
