The Mode button on the bottom left hand side will set your "SET" buttons to work. The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject. Pressing the bottom right button will reset your Stop Watch to zero. Press the Mode button to release your Stop Watch function and return to the Telling Time function. Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour. Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number. (If you hold any number changing button for a long time, the numbers will flash through rapidly.) Press the mode button to release your Alarm setting function. Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function. To enable or disable the hourly chime press the top right and bottom right buttons simultaneously, you will see the alarm sign appear or disappear.
Jev, thanks for your instructions on watch. Kenneth Cole Men Smart Watches Automatic Watches Leather Watches
Women Watches Kenneth Cole Digital Designer Watches
WATCH IT Canada Kenneth Cole Watches
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
SOURCE: need to fix my Kenneth Cole KC3754
You can order the spares from here.
http://www.bluenile.com/watch_brand_warranty.asp?warranty=kenneth_cole&nav1=
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
SOURCE: change the time on my cardinal LED watch
I am unsure how I did it.....I was just simply pushing buttons and then the time started flashing...the minutes...then I lost it again...then when I hit the buttons again...I got the flashing minutes then selected another button and it went to the hour...I advanced the hour by 1 hour, which is what I had wanted to do....so my problem is solved....Unfortunately I can't explain how I did it.
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy
"www.armitron.com/watch_instructions.asp" into your search engine and
you will see a list of illustrations of watches and associated
instructions.
Choose
the one that looks like yours and download the PDF file.
Its a very good instructions. could you please tell me how to set weekdays in UL1159 as my watch is showing Thursday and it is Friday today. Thanks in Advance.
