How do i work a challenge 3.5l ultrasonic humidifier, as it come without a manual.
The challenge 3.5 ultrasonic humidifer is very similar to the Vicks one on the inside (same nubuliser etc.). It's manual is here
http://www.kaz-europe.com/wp-content/uploads/VH5000E_OM_01JUN11.pdf and its made by www.kaz.com - they manufacture humidifiers under a few different brand names.
The vicks cleaning instructions are more stringent, I think because they are marketing this as a children's humidifier - they recommend bleaching the unit.
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
SOURCE: Sunbeam Ultrasonic Humidifier SUL495 quit working
Same problem. It worked for about a week, then gradually stopped producing mist. No solution.
