Ext memory in the ext jack on rear of unit not recognised check ext memory turn power off then on.
SOURCE: bought s350 blue ray dvd player. when tried to
I had the same issue. it is not recognizing the disc. I called in and I am having to send it in for servicing. The message you are getting is because the only option you are getting is the BD data one and not the one to play the disc.
SOURCE: not playing blu ray discs
Did the Live Chat with Sony, and they said if you reset the unit (unplug it for a minute and plug it back in) that should fix the issue. If it does not (in my case, it did nothing) the unit needs to be sent in for service. I'm taking mine back to the store in hopes for a refund. Good luck!
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
I did not receive an usb with the player. Can I use any usb external memory for the unit?
There is not a socket market USB...only EXT...but that looks like a slot for a USB. Will it still work?
