I bought this treadmill around Christmas and have been using it since JAN 2012, so its fairly new. However, lately when I use the manual setting the time clock and other settings (calorie burn count, mileage, etc.) just freeze up! The belt continues to work along with the incline and speed, but I have to turn it off and back on and then it usually resets itself so I can continue to know how far and how long I am working out. Grr..I guess my console is starting to go bad on me?
Dear Sir:
The problem is a( Faulty batteries b( Tight the flexible cables from keypad vs display board 3( tight the connector from display board vs lower board 4( adjust the Reed switch see the diagram for ilustration 5( Main motor board is faulty.
Try to run the software calibration for diagnose and trouble.
See my personal TIPS for HELP.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
SOURCE: Our Nordic Trak treadmill squeaks very loudly when
It sounds more like it is broken in rather than broken.
If it's worse than it sounds, I'll need more details
SOURCE: My Nordic Track Elite XT's belt will not start.
most likely the little plastic cover on one of the motor brushes popped off.
it's curved, but rectangular in shape and about the size of a quarter.
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
SOURCE: Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
