Hi...I own a lenovo z570 ideapad laptop and since past few days the volume automatically goes up if i go from one application (using sound) to another application. It works on windows 7 and drivers are realtek. Please help me...
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: WEB CAM IS NOT WORKING
Hi satyadevbujj,
Based on concern, Y510 camera driver for Windows 7 is not yet released based on Lenovo's support download site. Hence, you still can try updating the camera using the windows vista camera driver. Just go to this link.
--> after downloading, install the driver then restart your computer.
Hope it helps,
Thank you for using FixYa.
SOURCE: For the past few days my Lenovo IdeaPad Y430 has
Hi verneaimable,
I'm glad to help you out with the boot up issue of your Ideapad Y430. Based on the details that you have provided this is leading to a software issue. To address this concern, you need to reload the Operating System of your machine. OS has been corrupted causing you not to boot up on Windows. Lenovo do have this One Key Recovery button that you can use. You need not to worry because I have step by step procedure below making it easy for you to do the process:
Discalaimer: Using the One Key Recovery will put back your machine to it's factory settings. Any important file/software you currently have will be wiped out. You might want to create back up copy first of all your files before continuing on the process.
Steps:
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer. You'll now have the operating system reloaded to your pc. This should fix the issue.
Hope it helps.
Thank you for using Fixya.
SOURCE: One touch recovery in lenovo
Yes. Everything will be reformatted and erased so you'd need to backup your files and programs first before doing this.
What the One-Key Rescue does is it reformats the partitions on the hard drive and then reinstall the pre-loaded software that came with the computer just like the first day that you bought it.
One more important thing after the recovery is done, you might notice that MS Office (for MS Excel, MS Word, Outlook etc.) might ask you to enter the Product Key because it will only run as a trial version. So if you haven't purchased the full version yet, you might want to consider this before using the One-Key Rescue.
Hope this helps.
SOURCE: Sound is very low in
Hi and welcome to Fixya!
If you're not computer savvy or you wanted the easiest way to solve this, call the ideapad warranty support on this number 1 877 453 6686.
They can control your machine remotely and solve the issue right under you're very eyes =)
Hope this helps!
Green means you have a full battery charge.
So probably it seems your battery is out of juice. Keep it on charges & it should be fine.
If there is nothing changed, you may need to exchange the laptop charger.
Lenovo IdeaPad Z570 AC Adapter
Hope this helps.
