Sewing Machines Logo
Posted on Mar 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Janome 8077 instructions - Sewing Machines
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Mar 11, 2012
Level 3:
Answers
7365
Questions
Helped
1742658
Points
19451
Check with Janome customer service about a manual
Janome 1008. How to raise feed dogs on it please?
Here is your manual
JANOME 1008 INSTRUCTION BOOK Pdf Download
ManualsLib https://www.manualslib.com > ... > 1008 -
View and Download Janome 1008 instruction book online. 1008 sewing machine pdf manual download.
How do you oil a model 8077 Janome sewing machine?
Consult manual if you don't have one search the internet with your sewing machine model number...Example...name Model number and free download.
1helpful
Bobbin thread is jammin up after about 3 rotations of wheel on my janome 8077 - is this a timing problem?
try changing the needle
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not over filled
make sure the bobbin is not damaged
it's very possible that the machine could be slightly out of time
Need a manual for Janome overlocker JL603A
I found a digital copy of the Janome JL-603A Instruction Manual on Janome Sewing Centre's site: https://www.janomesewingcentre.com.au/shop/instruction-manuals/instruction-manual-pdf-janome-sewing-machines/?attribute_pa_janome-models=janome-jl-603a
1helpful
The needle and thread get stuck at the bobbin and the lo light come on my 8077
Turn the power off and replace the needle with a new one, making sure the install is as described in the manual for your machine - on most newer models, this is with the flat side of the needle shank facing the back of the machine.
Before turning the power back on, raise the needle to it's highest position. Remove the face plate, bobbin and bobbin case. Clean the area in and around the shuttle from lint and/or threads that may be tangled there.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
