you need to tie up the drain hose under the sink above where it connects to the drain spigot to stop the sink water flowing down into dishwasher instead of the drain. A blockage in the sink drainage can also make the condition worse.
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
Usually it is due to poor draining ie. garbage disposal clogging etc... If it connected to the garbage disposal get a bucket, disconnect drain hose and run rinse and hold drain line over bucket to see if it is draining at all. It should drain completely if it is showing it is trying to drain it is a blockage in the pump underneath. but try the hose first and go from there.
Would this be the float assembly?
