I have it completely dissassembled but the screen seems glued to the front plastic of tha laptop
Ummm, i'd doubt that it is glued unless you had the screen repair previously by a shoddy repair shop. First of all normally the screens are held in place by screws that are hidden by little rubber bumper covers or some type of covering on the plastic that is around the screen. Use a safety pin or small flat head screwdriver to remove the covers and expose the screws. Then use a phillips head screw driver to remove the screws. Once all the screws are removed use your fingers to slide along the inside of the plastic around the screen and pry it loose from the screen.
SOURCE: install vista to hp pavilion dv5 laptop
Make sure the laptop meets or exceeds the resources needed to run Vista. For all versions of Vista, at least a 1 ghz processor or higher, and 20 to 25 GB of free space on the hard drive. Memory: 512 for Vista Home basic, 1GB or higher for Vista Home Premium, Business, or Ultimate. The video in the laptop must be 16 mb or higher. You MUST meet the minimum requirements or the install and startup will fail.
SOURCE: need free fingerprint enrollment wizard driver for
Go to this link and select your OS:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3769832&
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: hp pavillion dv5 1104tu laptop problem with down
If you're able to get online, try looking here, and download the driver for your operating system http://www.synaptics.com/support/drivers
This should help you with your issue, and also give you the ability to tweak the way you want your trackpad to respond.
SOURCE: Can't play DVD on VLC on HP Pavillion dv5 running Vista.
try Power DVD or another player like Windows Media Player for your dvd,VLC player could be corrupted or reinstall the player,recent updates can also change the functionality,
Misterdj
SOURCE: I am using Vista, in my HP Pavillion Dv5-1116em,
Check you audio drivers are installed properly and that you have the newest cersion of them and yahoo messenger for vista
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Testimonial: "Cool!!! i can now fix my HP laptop with vista that does not work fully in yahoo messenger. Audio and mic problem. Thanks to FixYa... really reliable!!"
