When water drains there's a distinct rotten egg smell. The washer is only 3 years old. i have the same problem. I almost never use hot water, so that's not the problem. Running a load with bleach helps a little. Is there any way I can get the water to drain better?
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
SOURCE: Rotten Egg Smell
Let me guess, you smell it when you use hot water to wash? sounds like it is more of a hot water heater problem with the rotten egg smell you mention. This happens when the "sacrifical rod" in your hot water heater needs replacing. Inside every water heater is a long magnesium bar called an anode rod. The sacrificial metal protects the tank from rust by corroding first. Once the bar disintegrates, however, the tank begins to corrode. You can at least double the life of your heater by replacing the rod before it dissolves completely ? every four years or so, depending on your water quality. Hope this helps. Joe
Lousy LOUSY Machine...
LOSERS AT LG will not help....what a waste of money...
Bastards
