Question about Timex 1440 Nylon watch
Changing time-for day lights saving time on watch
How do i change the time on this watch to just set it back an hour??
  • 4 Answers
A. Press and hold MODE until HOURS digits flash (you’ll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
Posted on Nov 08, 2008
SOURCE:
I have a Pulsar watch need to change to day light saving time
just put the hour hand forward or back 1 hour
Mar 15, 2016 | Pulsar Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Adidas digital watch adp6042 i have press something and now i have offset when i try to set time on the left top button. How do i get it back to normal? Please help
To set the time for Adidas - Model ADP 6042
1. Hold SET/LIGHT (upper left button) for 4 seconds.
2. Press MODE (lower left button) to select the option that you want to change.
a. light
b. chime
c. 12/24 Day format
d. hour
e. minute
f. second
g. year
h. month/day or day/month format
3. Press the START/STOP (upper right) and LAP/RESET (lower right) to change the value for the options indicated in number 2.
4. Press the SET/LIGHT to save all the changes made.
Source: Allan T.
May 21, 2014
Feb 28, 2013 | Adidas Watches
My timex 1440 sport watch has buttons that are slightly different than any manuel I can find on line. the buttons are as follows going clock wise from top left mode, stop/start,adjust,and indiglo. I just...
Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
Jan 19, 2018 | Timex 1440 Nylon watch
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Can you please tell me how to set my Rolex Oyster Perpetual Datejust? Day light savings toime ends this evening and the watch needs to be set back 1 hour.
    Unscrew the crown and then pull the crown out to the second click and turn. When done push the crown back in and screw the crown back down.
    It is very important to screw the crown back down. If this is not done the watch is NOT water resistant.
    Hope this helps.
    Ken
    Yellowstone Watch Inc.
    www.yellowstonewatch.com
    Oct 31, 2009 | Rolex Datejust SS
    Cannot change from 24 hour to 12 hour also did not change to daylight savings time
    To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
    Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
    Time keeping.
    Check in the instructions about the time zone setting and that the feature for auto day light savings are turned on.
    If you go to the manufacture site for many of these watches, they have downloadable PDF instructions. They also have service centers that can give support.
    Jerry G.
    Mar 18, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Armitron Watches
    From the time telling mode press the set button the seconds will flash.
    Press the mode button the hours will flash
    Press the adjust button to change the hours
    Press the mode button the minutes will flash
    Press the adjust button to change the minutes
    Press the mode button the month will flash
    Press the adjust button to change the month
    Press the mode button the date flashes
    Press the adjust button to change the date
    Press the mode button the day flashes
    Press the adjust button to change the day
    Press the set button when done.
    Mar 11, 2008 | Watches
    How do I change time on timex watch?
    These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
    These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Have fun! - Not a bad watch for the money! - - Silver Bullet
    Mar 16, 2007 | Timex 5B841 Wristwatch
    Timex 1440 Nylon watch Logo
    259 people viewed this question
    Top Timex Watches Experts
    freddyfox
    Jerry Greenberg
    Jerry Greenberg
    Dustin
    Dustin
    Are you a Timex Watch Expert? Answer questions, earn points and help others
