A205-s5000
SOURCE: TOSHIBA SATELLITE A205-S5000 WORKED THIS MORNING,
It sounds like the battery is done...happens a lot. You may be able to just by a new battery pack to solve the problem.
SOURCE: acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
SOURCE: I want to Restore it to factory settings
The best way is with the Operating system disc and do a fresh install, thus wiping all installed programs and data files.
SOURCE: toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
