Sigma Sport BC 1609 Cadence Wired Computer Logo
Lindsey Cochran Posted on Mar 10, 2012
Sigma BC 1609 Cadence Bicycle Speedometer reads my movement much slower than I am actually going. E.g. moving about 15, reads as 5 mph.
Cadence sensor works perfectly. MPH readings, not so much.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
581
Points
I had the same problem. It is caused because the mount is facing the wrong direction and your computer is swapping speed and cadence. 5 mph would mean 63 RPM of the wheel which probably what your pedal is actually doing. The wheel is actually turning at about 3 times that rate so if you check your cadence it is probably maxing out at 180 even though that wouldn't be possible.
To fix this, just twist your mount 180 degrees on your handlebars or stem and try again. That way the computer is correctly lined up with the mount.
Jimmy OCallaghan
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Mar 10, 2012
Jimmy OCallaghan
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
Helped
4067
Points
36
How did you enter the details for your wheel size?
circumference is calculated by diameter * 3.14.
if you typed in the diameter by mistake then that would account for the times 3 error. it thinks your wheel is 1/3 of the actual size.
Hi. My sigma will not always register speed/distance. Any ideas to fix this issue ? Thanks
Check the fuel lines. Disconnect them and clean them by blowing air through them.
Bc 1609 manual
It's available from the Sigma Sport site.
The link is in the menu on the right.
Can the spoke magnet go on the rear wheel sigma bc 906
You should be able to use it on your indoor trainer. The Sigma will need a wheel diameter callbration to give correct readings.
1helpful
Sigma wireless bicycle computer. Model BC 1606L. Wireless cadence monitor has abruptly stopped working. All other functions of this unit working perfectly. Transmitting unit and receiver have new...
Did you throw the magnet on the crankarm? If not check the alignment of the transmitter and the magnet - sometimes they need to be quite close. Sometimes they just fail. I have seen instances where cadence worked and speed didn't and vice versa - so the unit is transmitting perfectly, but one of the sensors has gone bad.
My Sigma BC 1106 bike computer won't register the movement of my wheel. I spin the wheel and the speedometer stays at zero. I changed the batteries, the magnet on the spoke is still magnetized and I...
I had this problem as well. What I found was that the transmitter path from the magnetic sensor to the computer is very narrow, a 15 degree cone. Reposition your computer to fall within this cone. It should pick up the signal.
Mph won't register,all other functions seem ok
check battery in wheel sensor or adjust wheel sensor til it just misses spoke sensor fixes most issues
1helpful
Lost manual
WHY? Accuracy. Most of the Harley-Davidson motorcycles I've owned have had fairly accurate speedometers, but it's very common for the import bikes to be off by a considerable margin; the V-Strom is no exception. Realizing that my speedometer was reading higher than my actual speed, I cranked up my trusty handheld Etrex GPS and found that the stock instrument was off by a consistent 7.7% (when the speedometer reads 70 MPH, actual speed is 64.6 MPH). I figured that I had four options to deal with the problem: 1) ignore it, 2) watch the speedo and "guesstimate" my actual speed, 3) install an auxiliary speedometer, or 4) install a correction device.
Options 1 and 2 didn't much appeal to me. Installing an auxiliary speedometer is certainly a viable option, as some bicycle speedometers are very reasonably priced and can be calibrated to function with respectable accuracy. I was surprised to find a newSigma Sport BC500 unit on eBay for only $10.95 plus shipping, so I decided to check it out.
SERVICE. N/A. The eBay seller shipped promptly.
INSTALLATION. A piece o' cake, and one that could be accomplished by just about any owner. While the installation instructions are for a bicycle (go figure) it's not difficult to modify them for use on a motorcycle. The first order of business is to measure the circumference of the front tire and program the results into the unit; the measurement must be precise so that the readings will be accurate. The unit fits into a base that is easily attached to the handlebars with a rubber O-ring and a lead wire that is attached to a magnetic pickup. You'll need to find a way to attach it to the lower fork leg; since I only planned to use the unit for a short time I secured it in place with a heavy rubber band. It also comes with a magnet that's designed to attach to one of the bicycle's spokes. Since it obviously won't work on the V-Strom's front wheel another magnetic source must be used. Off to the local Radio Shack to pick up a pair of tiny rare earth super magnets ($1.89/pair, part #64-1895). These magnets, though very small--about 1/8"--are very powerful. I fit them into the head of one of the front brake rotor bolts, where magnetic force held them in place nicely. Here's how things looked;
sigmasportpickup.jpgRESULTS. Pretty darned good. Because the magnetic pickup detects only one pulse signal per revolution (the V-Strom's speedometer registers about 80 signals per revolution) there is a small lag in displaying the speed but at constant speed it's very accurate.
Worth the money? Absolutely. I don't plan to use the unit permanently, but it's an incredibly inexpensive way to provide an accurate speedometer reading. At less than $20 for the entire setup it's a heckuva deal!
Top Sigma Sport Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
