SOURCE: Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
SOURCE: How do I remove the handle of an upright Kenmore
The screws usually go from inside out and are under the inside panel. Unless you have the universal handles that switch sides and there is a screw on to and one on bottom.
SOURCE: frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
SOURCE: Have an Amana Side by side refrig/freezer (model
The handle covers can be slid off straight up for the top one and straight down for the bottom one you'll get some resistance but they will go.
bottom of handle is a screw hidden behind a square little sticker thing. use a small screwdriver to pry it out. take out screw and then push handle upwards and it will come off a clip which you can now tighten. then snap top secti0on of handle back onto clip and then lower screw secures it.
