G720 - HJA0530 built in gas oven
SOURCE: I have a stoves 720 gra with both ovens working ok
good day,
hope this link below will solve your problem.
ovens
SOURCE: Fitted new mainoven thermostat to Stoves Newhome
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
