SOURCE: 4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
SOURCE: I just received my new
That signals that the battery is charging. Leave it like that for at least 10 hours - the battery needs to format during the first charge.
If the situation doesn't changes after 18 hours then the charger is defective - the voltage it delivers is too small. The charger will have to be replaced for free under warranty - contact them at 1-800-772-3852
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
