Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Nov 02, 2008
Lawn mower dies
I start the mower and it will run for 5 minutesif that. After that it starts to sputter as if there is no gas in the mower, then it finally dies out and can't be re-started for 10-15 minutes later? What is the deal?
  • 2 more comments
  • dadix Nov 03, 2008
    I basically have the same problem, I can make mow for about 5 minutes then the motor chokes out.
  • jkurtis Mar 01, 2009
    regular lawn mower ...starts then stops...not getting gas i think...stops running when the primed fuel runs out....i should have taken shop instead of art....hoses filter and plug all new
  • Anonymous Apr 13, 2009
    Engine would run for five minutes and die. i enlareged the hole in the gas cap using a drill bit and the problem seems solved.
  • Ancient god of gaming
    Ancient god of gaming Sep 08, 2018
    I wouldn't open a hole in the fuel tank cap. 90% of all small engine problems revolve around bad fuel/contamination in the tank. If more dust and debris can find it's way into the fuel, the problem won't get better.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
991
Points
6
I had a very similiar issue, try this, when the mower starts to die, unscrew the gas cap, if it starts running again, it is creating a vacuum in your fuel tank, you can get a new gas cap, or drill a small hole in it to allow a bit of air inside.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 16, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
6244
Points
8
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Clint Hemsworth
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Nov 01, 2013
Clint Hemsworth
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
Helped
10971
Points
18
Bad gas? Water? Air filter plugged causing it to choke and sputter? Wouldnt kill it though. Sounds like water trying to be spent in bowl? ,or I'd say like almost always, clean carb , main jet gets plugged, bowl can't fill fast enough till it dies, then while sitting bowl fills back up, then runs till sputters then die.
1helpful
2answers
2answers
5.5hp 21" Bolens Sputtering problem.
did you leave or use gas from last year? drain it and try fresh gas if not take the carb apart and clean it
Apr 20, 2012 • Garden
2helpful
2answers
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
MOTOR STARTS, SPUTTERS THEN DIES
Carburetor clogged up, air filter clogged, spark plug fouled; old gas.
This is the best suggestion I can come up with on the information you gave.
2answers
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
1helpful
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
3helpful
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Apr 05, 2009 • Garden
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
