Enter serial number please call service engineer
NOTE
• When Main-power was turned ON while the Serial No. was not entered (including
initial status), the message to require entering the Serial No. will be displayed.
Make sure to enter the Serial No. at setup. sound like some did not follow the set procedure. go to service mode and enter the machine serial make a mistake machine will be out of commission
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub C252 printer Problem
You should be able to get Konica Direct to take care of it.
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
SOURCE: printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
SOURCE: Have a Konica Minolta C252
Please check this thread if it will help:
http://www.copytechnet.com/forums/konica-minolta/34546-admin-password-bizhub-c252.html
