For all of dads and moms that love to stay home to take care of their loved ones, or rest of people on the search for an opportunity to pull in some extra income for their family month after month let me share a remarkable opportunity to explore...Read more here.......http://www.fox120.com/
Hey Anon, Run a compression check..screw the compression gauge into the head until the o-ring seats..( a coat of oil on the o-ring helps) hold the throttle wide open and kick it over about 6-8 times HARD.. you should get at least 120psi..if it is lower than 110psi you need to find out why... if you don't have the tools/knowledge/experience .. .. take it to a qualified pro...
Place the camshaft into the cylinder head such that the marks on the camshaft gear are aligned with the upper edge of the cylinder head The stop bolt of the automatic decompressor must be on top. NOTE: When mounting the camshaft, you have to use the crankshaft fixing bolt to block the crankshaft in the TDC position. Place camchain on cam sprocket & fit link
Thank you for contacting FixYa with your inquiry. I have been going
over some of the older help requests that have been archieved and
trying to provide solutions for those that didn't get answered. Hope
this information helps.
KTM Torque settings
Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
Hi bengriffith1
You can download a copy of the engine manual from here
It has all the info you need. Any problems with the download just let me know
regards
robotek
