MSDC stands for Mass Storage Device Class. It is the most significant part of camera, which is required to bond camera and computer. If there is any damage/corruption in internal File System structure of the card then MSDC fails to detect the card, so MSDC read sector or MSDC write sector error in memory card arises.
Are you charging it by plugging it into a computer? The "MSDC" you see usually means "Mass Storage Device Class", which basically means the computer is using the storage on the camera as a removable drive. This would usually happen when plugging a camera into the computer via USB. There is usually an AC adapter that comes with a camera, or a separate charger for just the battery. If there was no charger that came with it, the camera is probably still charging. If the camera is on, try turning it off and plugging it in. Remember, even if it shows "MSDC", it is probably still charging. Hope this helps!
If you're plugging it into a USB port on a computer, then it's perfectly normal. The MSDC is merely telling you that the camera recognizes it is connected to a computer.
i have the same camera and the same problem but i have found out msdc means mass storage device, for the camera to work you have to have a memory card inside it. im getting one tomorrow for mine, so hopefully that should solve the problem :)
