Baume Et Mercier Hampton City Leather Strap Silver Dial Steel Chronograph Automatic 8344 Watch for Men Logo
A
Anonymous Posted on Mar 08, 2012
I bought a baume & mercier hampton 8823,when i was adjusting the hour i noticed the minute hand was not moving? is it normal or should the minute hand move as well?
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on May 05, 2007
SOURCE: Date changes at the wrong time.
The hands must be adjusted.fairly easy fix
Anonymous
  • 26 Answers
  • Posted on Jan 03, 2009
SOURCE: How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Anonymous
  • 65 Answers
  • Posted on Jul 24, 2009
SOURCE: baume & mercier hampton city watch
Does the dial have "Automatic" wtitten on it". If it does then it's a mechanical movement. If it has "Quartz" then it requires a battery. If the watch isn't running perhaps it just needs a battery. This may also explain why the pushers aren't working. If it's mechanical the watch needs to be wound before the pushers will work. What are the markings on the subdial.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 16, 2010
SOURCE: Unable to set the dual time on my new watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to B&M watch manuals.Rate me, please
Anonymous
  • Posted on Dec 16, 2011
SOURCE: proper battery for Baume Et Mercier mv045063
379
Can i change the battery in my baum & mercier acier inox watch or do i have to take it to a dealer.
mcdevito75 here, On this make watch it may be best to bring it to a small watch repair shop in your area. Unless you have changed many watch batteries you could end up scratching the watch, damageing the crystal etc. anyway, the battery is good for a year so why take the chance on hurting the watch.
1helpful
I have a Baume Mercier Cat Walk watch - the watch band is stainless steel with black rubber inserts - i lost already 2 of this black inserts, where can i get replacements
Follow this link and find the nearest to you:
http://www.baume-et-mercier.com/retailers?type=2
There is no other way to find the pieces you want.
Rate me please.
I recentlt purchased a Baume & Mercier
mcdevito75 here, best Bet, visit a jewelery shop in your area, they may be able to order a new manual for your watch.
3helpful
7helpful
3answers
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Baume & mercier hampton city watch
1helpful
Seconds hand does not move,minutes,hour hands ok
Friends:The watch is fine,I did not know how it works,a friend explained this to me.Everything is OK now,thanks for your help.Roberto
Top Baume Et Mercier Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Baume Et Mercier Watch Expert? Answer questions, earn points and help others
