When I press the home button it don't come on. The lights would still blink even the glow light comes on.
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: Mad Catz Lynx Wireless Controller PS2 with blinking red light.
I have one of these and what i usually have to do is plug the little part in which plugs in to the ps2 then let that load for a few seconds then try turning on the controller.
Hope it helped =]
SOURCE: Why is it not working?
re syncing the controller with the ps3. by holding the small button in the back of the dongle that came with this controller. Plug that dongle in like normal and hold the button in the back for 3-5 sec. This should reset and fix the problem.
SOURCE: Mouse light keeps blinking.
You need to make sure that the mouse is near the receiver, or that the reciever didn't fall down or got moved too far away from the PC/desk or the mouse itself. Furthermore, check to make sure that the batteries you inserted were new or fully charged batteries.
SOURCE: All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
