SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
OK, you just have to put those values into the equation, do the math, and see if it works.
-6 * 5/6 - 7 * (-2) = 9 does it?
-5 - (-14) = -5 + 14 = 9 yes it does
You can (and probably should) always check a solution by testing this way. The definition of a solution is a value or set of values that cause the equation to work out. If the test had failed (say we had gotten -6 = 9 before, which is obviously wrong), we'd know that the values weren't a solution.
5x -2(x-2) = 6 -2(-3x-3) 5x -2x +4 = 6 +6x +6 (use the distributive property) 3x + 4 = 6x + 12 (collect terms) 4 = 3x + 12 (subtract 3x from both sides to get all x on one side) -8 = 3x (subtract 12 from both sides to get only x on one side) -8/3 = x (divide both sides by 3 to get x by itself)
The first step here is to draw a rough sketch of the two curves, and find the two points they meet. If you set x^3-6x^2+8x = x^3-4x, then you can rearrange this into the quadratic equation 6x^2-12x = 0. Solving this tells you x=0 or 2 : these are the two x values where the curves meet, and they give the bounds on your integral.
When you sketch the curves, you'll see that x^3-4x is below x^3-6x^2+8x, so the thing you need to integrate is (x^3-6x^2+8x)-(x^3-4x), that is, 12x-6x^2. If you integrate this from 0 to 2, you'll have the answer you need!
6x+6=4x+12
Since 4x contains the variable to solve for, move it to the left-hand side of the equation by subtracting 4x from both sides. 6x+6-4x=12
Since 6x and -4x are like terms, add -4x to 6x to get 2x. 2x+6=12
Since 6 does not contain the variable to solve for, move it to the right-hand side of the equation by subtracting 6 from both sides. 2x=-6+12
Add 12 to -6 to get 6. 2x=6
Divide each term in the equation by 2. (2x)/(2)=(6)/(2)
Simplify the left-hand side of the equation by canceling the common factors. x=(6)/(2)
Simplify the right-hand side of the equation by simplifying each term. x=3
