If you can access your drive
click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the destination drive right click select paste or hold the mouse cursor the file/s drag them to your destination drive then drop them in
hope it helps
SOURCE: help for Seagate Free Agent 500 GB external hard drive
I just got a Free agent 500gb today and I checked from my computer to see how much actual space was available on the HDD and it showed the same amount that you're getting 465gb. I believe the 35gb that's missing is used for some standard program/files that the Free agent requires for regular operation.
SOURCE: knocked over my seagate 500 gb hard drive. makes a
you say its beeping? like an error code sequence? i would search the intnet for seagate error codes and try to match the code with the problem. or call tech support.
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
SOURCE: Seagate FreeAgent, 500 GB p/n 9nk2al-510 stopped working
There's not much troubelshooting you can do with a failed external disk. power off PC and hd and then disconnect all cables, wait 30 secs, power the PC on, let it boot to the OS, power the hard drive on and then connect. If the drive shows up but you still cannot access it or get weird property readings, it generally means the hd controller has failed. If the data's worth more than $1000, you can take it to a data recovery group like Ontrak or Cherry Systems, but otherwise, just get a new hd and restore whatever backups you have.
