Sharp LC-32SB24U 32 in. LCD TV Logo
Posted on Nov 02, 2008
The channel information/display won't stop popping up every few seconds.
I watch the TV and in the upper Left-hand corner the channel display box keeps popping up every few seconds. It only does it when i'm watching TV. It doesn't do it if i'm on a different a different input.
  • 3 more comments
  • foulduck66 Dec 06, 2008
    The channel information/display won't stop popping up and mono changes
  • Anonymous Dec 12, 2008
    same, again with a sharp
  • Anonymous Jan 24, 2009
    Have 2 Sharp LCD TVs; one is an Aquos, one a standard model LCD. Both have the same problem described above: the channel information keeps popping up, and the mono/stereo display keeps flickering.
  • emjackso Apr 02, 2009
    I don't have a cable box or a satellite box so I need a converter box like the ones used for the new digital switch?
  • Sharphelp Apr 13, 2009
    I have the same audio display fluttering. It doesn't occur when watching DVD's, just cable. It is on 90% of time as well. It's annoying and really just want to return tv, but wondering if there is a quick fix. Coax Cables don't make sense to me because my last tv was hooked up the same way and worked just fine. Anyone know how to fix this????
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Feb 19, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
21110
Points
69
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
4helpful
2answers
Bright green 3 in the upper right corner of my TV
press the display button on your remote.hope this could help you.u
3helpful
2answers
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
10helpful
2answers
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
1helpful
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
18helpful
5answers
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
