Maytag Neptune MAH55FL Front Load Washer Logo
Christy Perry Posted on Sep 22, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mildew smell and sound of water
I recently bought a neptune washer and dryer, my husband said it had good reviews but after having some problems with ours I did some research myself and found out otherwise. I have read everyone's problems with their washers but none of them seem to describe them same problem I am having. When you open the washer it smells like mildew, and you can hear water behind the drum. My washer washes my clothes fine and it drains and spins and fuctions properly. I however don't particularly like to open the door and smell mildew it is gross.
  • 2 more comments
  • okfine Dec 03, 2007
    Hi, I have the same problem. I tryed to google the service bulletin, but could'nt find it either. Will try what was suggested. Also, I'm wondering....isn't there some kind of filter to clean? we have pets, and I'm sure there is a bunch of muck somewhere.
  • Anonymous May 11, 2008
    we have the same problem also and are considering replacing with another brand if we can't find a solution.   Cleaned out washer, used bleach and run water in empty washer.
  • teacherC May 31, 2008
    ditto on the problem here too. The rubber seal that you see when you open the door is full of black spots. I have tried to wipe it down with bleach, comet, pine sole ... and so far NOTHING have help. It is frustrating and now I am beginning to notice that everything smells.
  • gatewaygirl Jun 29, 2008
    same problem here, makes clothes smell horrible.
    new problem is washer will not spin, door lock malfunction,
    and tear in rubber gasket around door/tub.
    maytag knows all about the thousands of defective units yet is only willing to acknoweledge a few.why charge thousands for junk? watch out maytag,
    what comes around goes around.
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Sep 22, 2006
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202203
Points
3312
Momma, Maytag put out a service bullitin on this problem. TB26-72. This is a common problem on your model. Why don't you google the service bullitin and it will give you the instructions they have for this problem. If you can't find it, post back and I will post them for you...Catriver...post back.
1helpful
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
1helpful
Smells like mold or mildew
Wash an empty load with bleach. This may wash out mold or mildew stuck in the water lines and pump. If it seems to help, do it again.
This is for internal issues.
If the problem is external, the machine may just need a good cleaning.
LG washing machine has AWFUL mildew smell
Don't know if this is the same as your problem, but I had a Kenmore washer, (made by Whirlpool) that did the same thing. It was a high efficiency model without an agitator. I finally found out that this type of washer never drains completely but always has some water left in it. This water is somewhere internal that cannot be seen unless the machine is taken apart. That water goes bad and stinks. Everything smelled like mildew and for some while my husband thought I was was washing clothes and leaving them in until they dried. I ended up having to just buy a new machine and when the stinky washer was taken away, just tilting it caused all this foul water to come out everywhere. Also I found this on the internet http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
scroll down and see how other people feel about this machine. I decided that instead of buying the newest, latest, greatest, with all the bells and whistles appliances, from now on I will buy the time tested, plain jane models.
Water between the drum even when not on
Water between the drum is a common problem with not only front load but top load as well.
Front load washers such as the neptune have an airtight/water tight door which will hold moisture in the machine when closed. Try opening door and keep open between loads. In addition, a monthly cleaner specific for the front load machine will help this problem
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
1helpful
2answers
Affresh
Try reliable parts. There are many locations across Canada and the US. You might also get the Affresh tablets at an appliance retailer or hardware store but I'm not sure.
http://www.reliableparts.com/
Here are some (mixed) reviews of the affresh tablets. http://www.buzzillions.com/dz_708669_whirlpool_affresh_washer_cleaner_reviews#reviews
but like I said in my post, you may have to run a few full cycles with the tablets to get a smelly washer clean and then maintain it by using the product every 1-3 months or so.
You could also try this product: http://www.smellywasher.com/
This is an review on their site:
"I have to tell you I am very pleased. Having an acute sense of smell, I always get teased for smelling odors that others don't. For about 6 months we've had a mold/mildew odor in our 1 1/2 year old washer. I found your site on the internet and ordered SmellyWasher.
I can tell you my husband was amazed at all the mold coming up and I felt "vindicated". Here is the other interesting side of things. Coinciding with the smell of the constant mold/mildew for the last 6 months has been the fact that I have been constantly sick. I came down with cold after cold after respiratory sickness along with the rest of the family since Thanksgiving. I was literally getting sick of being sick. The last bout was bronchitis with whooping cough.
After I did the cleaning out of the washer with your product and removed all the mold/mildew, I have NOT gotten sick since and have had 2-3 weeks without any respiratory problems. I have come to believe that it has something to do with me cleaning out the mold, and no mold residue on towels or clothing. My husband is coming to believe this also. It's so nice to breath in and NOT smell the mold.......
I love your product and have told several people about it.
6answers
Same here. We bought ours January 2005. Love the machines and take great care of them, too. Then the smell in the washer which seemed to affect certain clothes, like thick sweat pants and t-shirts (they smelled really "sour"). After doing some searches I found on this site where someone had recommended using a product called Affresh. I figured I might as well try it since my other attempts failed. This really worked for me. I bought it at Home Depot for $7 for a pkg of 3. I used 3 tablets per their directions, as this was my first time using it (afterwards they recommend using only 1 tablet per month). I was totally amazed as the smell was gone. I hope it works for you, too!
2answers
Water isn't completely draining
the water sound is normal ,to make the machine balance there is a liquid in the shell of the tub that is always there.As for the smell start leaving the door partially open and mold/mildew cant form.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
