Sony Walkman TCD-D8 Personal Cassette Player Logo
lamont cranston Posted on Sep 22, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repair Sony DAT Walkman?
Some time back, my TCD-D8 unit's servo mechanism that's used to open the cassette slot stopped functioning. There may even be a DAT inside currently, but it's not simply stuck, as flipping the "open" switch no longer activates the servo. Power to the unit IS good. Recently, while the unit has been sitting idle, but plugged-into its power source (been that way for over a year!), the servo mechanism started making intermittent sounds, of its own volition and a second or so duration. Obviously, something has gone brain-dead in the logic. Sony, according to their web-based support site, no longer even repairs this item! I've looked around... is there someone who can, that you might know of, and would the cost be worth it? Thanks to anyone who may be able to help, here.
  • 4 more comments
  • nuibeee Jan 08, 2008
    i have a tcd-d7 , when i load a tape an 10 error code flashes on? is it worth fixing?
  • cute_petal Jan 15, 2008
    even i am facing the same problem with my sony walkman
  • signofwater Feb 19, 2008
    I have the predecessor model (TCD-D7), and had the exact same problem. With much coaxing (cycling the power and hitting eject), I was able to get it to eject, however the unit can now no longer load tapes to play or record. The loader mechanism engages and attempt to load the tape, but spins its wheels and ultimately fails.
  • Maradnus Apr 04, 2008
    I have the same problem. i am happy to do the repairs my self i just need a manual to follow. has any of you out there have any idea how or ware i get one from?
    I have taken it apart  and cleaned it fully but to no avail.
    Any help would be great.
    Sunda
  • Anonymous Jun 23, 2008
    Im having a power problem with mine. :(
  • smookedawg Jan 09, 2009
    Ditto,
    I called Sony USA and they said they can fix the problem by servicing the unit. Also, since I'm from Canada they transferred me to Sony Canada. They too said they could fix the problem by sending the unit to their repair place. It might take 150 bucks to fix the problem but worth it all in the end.
    Call Sony and they'll be able to help. :)
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4821
Points
The "solution" by techman appears to be entirely inappropriate because the link he posts takes one to a company that repairs data storage units, NOT Digital Audio Tape (DAT) recorders.
  • Anonymous Oct 03, 2010
    hi all, i still offer a repair for the sony tcd-d3 tcd-d7 and tcd-d8 dat players have a look on my website for more info. all work is guaranteed.
    thanks
    andy
    andys electronic stuffhttp://www.andyselectronicstuff.co.uk/in...
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Sep 22, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649820
Points
8439
Try http://www.pacificdatastorage.com/repaircost.asp
Anonymous
Level 1:
  • Posted on Apr 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
4821
Points
I service all Sony portable DAT models. Please email for details:
[email protected]
Anonymous
Level 1:
  • Posted on Feb 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4821
Points
Leberman sound shows that they still repair these units.
http://www.libermansound.com/repair/dat.php
Plays tapes to slow
some time u can push play and ff or the rew and it work
2helpful
Sony tcd-d8 won't rewind
sounds like a belt slipping try renewing them they are fairly cheap to replace.sony tend to be very reliable but this is quite an old item now and belts degrade with time and use.farr64
2answers
No functions works....
This sounds like the internal drive belt has broken and the mechanism is not in a "final" position. The noise you hear is hte motor trying to get the mechanism back to a known condition. This should be a simple repair for any audio repair shop. Expect a parts cost in the $5 range. Add in the local labor rate for the total repair cost.
Dan
Won't respond to good batteries
Check and clean the contacts.
Also if you take the back cover off, you can see the red and black battery wires connected to the board. Make sure they are connected.
Distortion!
did you record them on the same unit?
It may be an alignment problem.
If it's the same unit, try cleaning the heads.
There are dat cleaning tapes too, but they beat on the heads.
Tape fails to return to cassette when cassette removed.
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: [email protected] Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: [email protected]
Sony walkman TCD-8
Clean the heads or use a tape cleaning tape.
2answers
Screw fell out - tape transport mechanism stopped working
If you are in the UK, I recommend 'Richmond Film Services' who have an excellent engineer. David
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
