SOURCE: call for service c26 in toshiba copier e 810
C26 indicates Peak detection error.
U need to make sure the exposure lamp is light when u switch ON machine.
If no light, then u need to check the inverter and the exposure lamp.
SOURCE: Toshiba estudio 166 C44 error code
Press "08" and ON machine.
Then enter "400", change the value to "0".
Then restart machine.
But if after cleared, it happen again, then u need to check the thermistor.
SOURCE: Toshiba E-Studio 810 says call for service when
check to see if lamp lights. if not, replace lamp.
if lamp lights, pull the platen glass and replace the scanner board under cover by lens.
SOURCE: I am having problem in taking printout from TOSHIBA E STUDIO 166
You are trying to print to paper size that is not installed in the machine. Check what paper is installed in the machine then set your software application default paper size to the same value and then print away!
SOURCE: ''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
