I push the power button and the led light turn blue then orange and it won`t turn on this happen all of a sudden
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The above solution will work for a while until the cap goes completely bad.
Cause of power going
off: There is a bad 1000uF, 16V cap
on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V
cap for $2. This will work.
Why did the cap go
bad? The cap is too close to a heat
sink and over heated.
What does this cap
do? This cap sends a signal to an IC
which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is
applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:
These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart
with a flat screw driver.
After removing the stand, you need to insert a flat screw
driver at the bottom of the screen where two slots are located. Then work the screw
driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit
board.
Unplug the monitor cords from the driver board and remove
the screen.
Unscrew the mounting screws from the power supply board and
remove.
You will need to pinch the plastic support in the middle of
the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be
on the side of the cap. It will be bulged up on the top. You will see burn
marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of
the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the
heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Perfect...worked like a champ.
You can try the following steps:
1. Disconnect all the cables from the monitor
2. Wait for 5 minutes and press the power button in the front once ( donnot connect the cables at this step)
3. Reconnect the power cable only to the monitor
4. Power on the monitor and check if you see a self test running on the screen
If the selftest feature is not running the monitor has gone bad. All dell monitor if purchased on a seprate order ,hold a 3 yr replacement warranty. If you have got the same with your dell computer, call Dell to check if its under warranty.
Thanks
proton
