Hello, Check if you find files on c:\windows\minidump ? if yes can you upload it and I will take a look.Hello, Check if you find files on c:\windows\minidump ? if yes can you upload it and I will take a look.
You can't post conmments that contain an email address.
ive got a kav60 netbook and the video and audio freezes, makes a nasty buzzing sound. i also have a problem with my mouse, it goes crazy, or sometimes doesnt respond unless i apply pressure to one side of the netbook (slightly bending). tried disconnecting the touchpad, and applying an external usb mouse, but it sometimes freezes the cursor,or the cursor does its own thing. please help
Download WinUtilities from download.com and run the registry and cleaning utility, and defrag. If no change! try a system restore and bring the computer back to an earlier time before this happened.
sounds like the bios battery is dead , it looks like a watch battery and may be soldered to the motherboard. I would trash it and get something newer. any new android phone or tablet would be better.I would suggest the 7 inch fire tablet for $50
Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM. 2. Click Start ' Run. 3. Type SFC/ ScanNow and press ENTER. 4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout. 2. Click Registry Cleaner tab. 3. Click Start Scan. 4. The registry scan will start. Wait till it is finished. 5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp. 2. Follow the instructions on your screen
there could be a system glitch in your windows operating system. since problem started 2 weeks ago. you can actually restore the computer back to the date where your computer is working fine using system restore. click start menu - al programs - accessiries - system tools - system restore.
