SOURCE: on screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
SOURCE: kogi monitor will not go black when turned off
Please provide me some answers to the following questions in order to provide a better solution. Also this questions may help you to better understand the nature of this problem.
1. Can you see an image on you screen? (even if it's distorded and shown only in one of these colors or randomly)
2. Does the monitor cycles these colors normally when it's not connected to a pc in order to make a self test?
3. Is the video cable properly connected to the computer and the video card is firmly attached to the motherboard?
4. Can you test the monitor using another pc?
5. Does light taps on the side of the monitor's casing change the pattern of the color cycling problem?
If these tips doesn't help, please provide some answers to these questions and I'll try to help you with some ways to fix the problem based on it's description.
SOURCE: Kogi Monitor
Hello there.
You need to enable the external display in your Operating System.
Please see http://www.mrhope.com/issues/ch000801.htm for information on the FN keys on your laptop.
Hope this helps.
SOURCE: I need a power supply for my Kogi L7EH-TA monitor
I found one from COMPUTERLOGIN . It was around $22.00 includeing delivery. 12V - 4 Amp.
SOURCE: Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
