Ido not reot control of supratech tv
Replacement remotes should come with the codes, the las 1 I got had a booklet of codes for various types and makes of device, some had several codes any you needed to try each in turn until you go to the correct code. Not sure if the different makes of remote need the same or differnt codes. I suggest you contact the remotes maker for the possible codes.
SOURCE: Direct TV Remote Control RC64 Code for Insignia TV
http://www.fixya.com/support/t1555766-direct_tv_remote_control_rc64_code this worked for me after doing a GOOGLE search. 10150 is the code that even worked for TV power. Here are the other codes supplied, in case link didn't work, 10463, 10054.
Good Luck!
SOURCE: DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
SOURCE: I have an RCA L40FHD41
try these codes " 11447 11347 11781 10029 12187
10747 11147 11247 11547 10174
10679 10774 11922 11948 11958
10038 10093 11661 11917 11953
12002 10051 10090 10278 11047
11919 "
if those dont work then try this: "
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
