Leviton Decora 30-15-10-5 Preset Minute Electronic Timer Almond #615-6230M Logo
Posted on Nov 01, 2008
Bathroom fan fan hums when connected to the timer.
bob will
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 03, 2008
bob will
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
2265
Points
Hi there might be a couple of issues. The first one how old is your fan, if it is an older model motor maybe running down? Try setting your switch on the fan at high. Also the polarity of wiring at the switch or the fan might be swaped. This means the white and balck wires may not be in the right polarity.
Can I connect two bathroom fan ducts to a single roof vent?
No, both cannot be connected to same vent.
Or vent exhause from 1 fan will vent into other bathroom.
All house vents require separate duct.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Broan S130A bathroom exhaust fan loud hum
The start capacitor for the fan motor is defective.
1helpful
My bathroom exhaust fan has a dial timer. Sometimes lately the fan does not come on for a couple of minutes after starting the dial timer. Is that likely to be a problem with the dial timer, or with the...
This could be the timer or the motor. The timer could be going out or not starting up in the right position. Has anyone worked or removed the timer knob, it could have been put on just a little off causing the switch to be off just a bit. Again the motor could be going out,such as the bearings inside. I would see what type of warranty is on this fan. I know these exhaust fans can get a little pricey, so I would see what warranty options I have.
I have two of these switches and they both are operating incorrectly. I use them to control bathroom fans in two separate bathrooms, but they both act the same. That is, when I push one of the time...
Leviton countdown timers have additional wire that powers internal electronics.
Leviton timers have red-black-white-green wires (or blue-black-white-green wires)
1) Regular single pole switch has 2 insulated wires. One of these wires is Hot from breaker, and the other goes to Load (fan)
2) Timer green wire connects to bare ground as you know.
3) Hot from breaker connects to timer black wire.
4) Load wire connects to timer red (or blue) wire.
5) Located in back of box are white wires that are twisted together and covered with wire nut.
These are Neutral wires. Connect timer white to these wires. This will power timer electronics.
6) If box does not have Neutral wires described above, then connect timer white to bare ground along with timer green wire.
7) Turn power ON and try timer countdown.
If timer does not work, then reverse timer red and timer black wire.
8) If box does not have neutral wires: Image on link below shows similar Intermatic timer:
Image applies ONLY when Neutral is not available.
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
http://www.homedepot.com/webapp/wcs/stores/
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
6helpful
2answers
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
I have a GE auto shut off timer #15069. It comes with a black,white and red wire. I am replacing an in wall timer for a bathroom exhaust fan that only has a black and a white wire. Can I connect this...
First, be certain that the power is off. The black goes to black, the white goes to white and the red goes to the fan, it is the switched wire....
Sep 01, 2010 • Home
4helpful
I lost my Leviton 6230M 30 mins timer installation sheet.
Switch has 2 black wires. One black is hot wire. One black is wire going to fan. Turn off power. Remove wires from switch and separate. Turn power back on. Using ordinary tester, test each black wire to bare copper ground wire. Only one of the black wires will test hot. The other black wire goes to fan.
Timer black wire connects to black hot
Timer blue wire connects to black wire going to fan
Timer white wire connects to white neutral (in absence of white neutral, connect Timer white wire to bare ground)
Timer green connects to bare ground wire
1helpful
2answers
How to lower the sound on a bathroom fan
One needs to install a bathroom fan that has a Sone rating of 1 or below. They aren't cheap :-( Sorry, there really isn't any other solution.
Top Leviton Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
