When i try to turn on my computer the green, orange lights come on and fans after about a minute the orange light goes off but the green light and fans stay on
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
SOURCE: Asus P4S800-MX Motherboard video problem
The system speaker is usually a set of four pins and you use the outside pair to connect the speaker. You may need to go to the Asus web site to download the manual if you don't have it. Try to reset the bios either by shorting the appropriate pins or by removing the battery for a while.
SOURCE: pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
SOURCE: No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: Dell Dimension 2400 won't turn off but goes off/on
The diagnostic code that you have specified is a memory related issue please try reseating the memory or swapping with a known good compatible memory stick in adverse case it can be the motherboard as you have specified that A & C take turn being yellow and green.
for more instructions please click here to got to a wizard which guides you through the step by step troubleshooting
SOURCE: computer wont power up. Light stay amber and fan come on
Remove the memory chips again and reseat them in thier slots. This typically happens when you dont get the ram all the way in it's slot. Computer wont boot.
Regards..
