Calculator
what am I doing wrong I can`t get the paper to feed through. It just goes down like it was going to come around and then stops. It seems like the roller is going the wrong way. Could this be a possibility? I have a Older sharp EL1197G11. Would appreciate hearing from you. Thank You Lucile [email protected]
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
I have the same problem, the paper won't go in far enough for the wheels to grab hold of it. It seems like the little rubber piece is keeping it from feeding through. I have a Unisonic XL1149A. Does anyone have a solution to this problem?
[email protected]
