Wear can i hook this wire is it to power or ground
Bypassing the EBrake wire is not a good idea. Should you have an accident as a result of watching moving video in the view of the driver (illegal in ALL 50 states) your insurance company will NOT pay the claim. God forbid there is a fatality, then you are going to be charged with Manslaughter as a result of inproper equipment. Best bet is to connect the PINK wire to the vehicle's parking brake.
SOURCE: Jensen vm9512hd e-brake bypass
the pink wire on the unit is for the E-brake.... ground it out somewhere and that will bypass the brake and fix the problem.
SOURCE: Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
SOURCE: parking brake bypass
The best solution and what i did was just plug the parking brake to the ground cable of the reciever...
And works perfect...
SOURCE: how do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
SOURCE: jensen in dash dvd monitors
I got this from another forum so don't thank me, thank psychedelic feta. I'm just passing it on, WORKS LIKE A CHARM!
FWD:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate
the brake sequence and disable the blue screen using the hand brake,
the switch method or anything else to give the unit its three pulses to
disable that freakin blue screen.
(What I did was I installed
my radio entirely, then took the pink wire and touched for two seconds,
removed for two seconds and then touched and held the negative pole of
a mower battery laying on my passenger seat until the screen was no
longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3)
Using the right joystick on the unit, navigate to the options of your
choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When
your done, click SYS SETUP on the main remote TWICE to save the
settings and bingo, your done!!! Hooray!!! You can now kill your whole
family in the car while watching that adult movie while your
driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If
you have more than one tv, the unit itself will have the blue screen
but the additional tv's you have plugged in will NOT, they will show
the dvd menu. Thus you will be able to see the hidden menu on the
additional screens after inputting the code, but not on the main unit
because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It
may take a few tries but you'll get it. This method can be done if you
don't want to bother temporarily activating the brake sequence, but if
you only have the unit and no additional tv's, its #$%^&* damn
hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. if you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By
the way, this is for informational purposes only and I will not be
responsible for anything bad/stupid/ignorant you do with your Jensen
unit.
