Minolta bizhub 200 All-In-One Printer Logo
A
Anonymous Posted on Mar 07, 2012
Bizhub Konica Minolta - Error Code C2257 - Minolta bizhub 200 All-In-One Printer
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Mar 01, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910734
Points
11959
Replace the developer. If that does not work replace the ATDC sensor located under the image unit. Has multi-color ribbon cable. If not that then the main control board. Best bet would be replace the developer and ensure you clear the counter for develop and run the F8 process after replacing the developer. DO NOT USE A VACCUM CLEANER to replace the developer because the static electricity from the vacuum cleaner can destroy the sensor. Also the copier uses the counters to adjust voltages for certain assy. so if you replace the developer and don't clear the counters then the machine will adjust voltages for a used drum or developer when in reality the developer or the drum are new. Causing image problems and codes such as 2257. Also recommend the drum and cleaning blade be replaced, does the control panel in the upper left say replace the PC drum?
Try this site for the parts:
T
Try this site for the partsT Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2 Related Answers
Anonymous
  • 1110 Answers
  • Posted on Aug 03, 2010
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
O que posso fazer para remover o erro de codigo C-D252 na Konica Minolta C364 bizhub
English only on Fixya please. We are a North American website.
Error Code Pls help - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Jun 20, 2012 - CD252 (C-D252) code at start up. Solution CAUSE: The Controller 1 setting is enabled in Tech. Rep. Mode without the IC-409 (Fiery® ...
fuser error code C252
May 7, 2014
Bizhub C451 bad print quality, no accurate color
Jun 4, 2014
Error Code Bizhub 283 with C-D272
Mar 17, 2016
error code C- D251 bizhub C451
May 19, 2009
More results from www.copytechnet.com
Konica-Minolta bizhub C452 - Error Code
Printcopy.info https://printcopy.info > model=bizhub+C452 Code: CD252; Description: No relay circuit boards for IC-412 mounting at IC-412 mount setting; Causes: MFP board (MFPB) Relay circuit boards (VI-505) .
2answers
How to fix trouble code c2257 hizub c652
must we guess what that is , in he office blind.
ok forced to google me, I will bite
a multi mode printer scanner fax?
did you read the manual first. and the diagnostics and test pages?
real name
Konica Minolta bizhub C652 there are free mirror manuals here
https://www.manualslib.com/k/konica+minolta+bizhub+c652.html
2257
  • Cleaner motor's failure to turn
    • The motor lock signal remains HIGH for a predetermined continuous period of time while the motor is turning.
  • Causes: Cleaner motor (M38) Printer control board (PRCB)
1 Check the M38 connector for proper connection and correct as necessary. - - 2 Check the M38 connector for proper drive coupling and correct as necessary. - - 3 Check the PRCB connector for proper connection and correct as necessary. - - 4 M38 operation check PRCB CN2-3 (REM) PRCB CN2-6 (LOCK) K-11 5 Change M38 - - 6 PRCB ICP18 conduction check - - 7 Change PRCB
first google it, BTW ever google
https://printcopy.info/?mod=erc&brand=Konica-Minolta&model=bizhub%20C452&code=C2257
2answers
Konica-Minolta Bizhub Pro 950. I have code C-8003.
Konica-Minolta bizhub Pro 950 - Error Code
Printcopy.info https://printcopy.info > model=bizhub+Pro+950
Code: C-8003 · Description: When the main power switch (SW1) is ON, there is no response to the initial communication request from the main body to the DF even ...
How to remove error c2257
DEEPAK, YOU NEED TOMORROW TO CALL MINOLTA CUSTOMER SUPPORT FOR PROPER WAY TO CLEAR THESE CODES!THAMKS
Error code C2257
Cleaning motor, motor functions to route old toner to waste toner box, motor located lower left side rear. Open close front door to reset if code comes back motor is bad or have a bad board. But first remove the transfer belt and check it cleaning system also the waste toner box, might have some toner that has harden and is not allowing motor to turn recommend get a KonicaMinolta tech to look at it.
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
